'GM OLD LOOK ODDITIES'
Goto page Previous  1, 2, 3 ... 24, 25, 26
PostPosted: Mon Jul 10, 2017 4:59 pm    Post subject: Reply with quote
These are 1958 model TDH-4512 buses delivered to the Birmingham Transit Co. from Sept to Nov 1958. Huntsville and Hollywood were early Birmingham bus routes. Avenue N (note street sign) is in the western part of the city.
Bus 702 (serial #2839) and 733 (serial #2870) were two of 100 models delivered and numbered 701 thru 800.
PostPosted: Thu Sep 07, 2017 3:47 pm    Post subject: Reply with quote
This is the results when you extensively modify a run of the mill GM old look into a motor home. If it wasn't for the front clip (and possible the rear clip), one would find the make of bus almost non discernable. Whoever did this conversion spend a lot of time and planning. This had to be a big hit at overnight camping sites.
 Filesize:  46.78 KB
 Viewed:  16160 Time(s)
PostPosted: Sat Oct 14, 2017 5:25 pm    Post subject: Reply with quote
A TDH-4512 from Nashville without an emergency door
 Filesize:  83.82 KB
 Viewed:  16025 Time(s)
Page 26 of 26
