Age: 68 Joined: 17 Apr 2007 Posts: 1800 Location: Central NJ
Posted: Sun Apr 29, 2007 6:02 pm Post subject: Name That Location #1 |
Name the intersection (there is no photo).
Here are the clues:
1.) Borough: Queens
2.) Bus Data:
-3 local NYCT bus lines pass through this intersection.
-Each route currently originates in a different depot, but this was not always the case.
-One route feeds an IND subway station.
-Two routes pass through the intersection, while one route turns here.
Good luck! |
Posted: Sun Apr 29, 2007 7:19 pm Post subject: |
Proving that I'm no BK when it comes to the NTL game, I must correct the Bus Data as shown below:
-2 routes currently originate in the same depot, while the 3rd route originates in a different depot.
-Two of these routes have swapped depots at least once during the past 10 years.
Sorry for the goof! |
Posted: Tue May 01, 2007 7:17 pm Post subject: |
The answer is: Utopia Parkway & 46th Avenue.
The 3 bus lines running here are Q26, Q27, and Q31.
The depots currently represented here are CS (Q26, Q31) and QV (Q27).
I believe that the Q31 and Q27 had swapped depots not long ago. |
