Age: 72 Joined: 27 Feb 2013 Posts: 1270
Posted: Sun Sep 21, 2025 12:43 pm Post subject: What if Flxible had an Articulated Bus |
Here are excerpts from a proposed Flxible articulated bus.
Besides the attached pages the pamphlet also had the history of the original Twin Coach and European artics.
The bus was to be powered with an underfloor Cummins diesel engine.
106.92 KB |
28691 Time(s) |
204.39 KB |
28691 Time(s) |
120.41 KB |
28691 Time(s) |
Posted: Sun Sep 21, 2025 12:44 pm Post subject: |
Continuation
220.65 KB |
28690 Time(s) |
137.7 KB |
28690 Time(s) |
176.95 KB |
28690 Time(s) |
Joined: 18 Dec 2007 Posts: 34176 Location: NEW JOISEY
Posted: Sun Sep 21, 2025 12:49 pm Post subject: |
An ARTICULATED "Dangerfield"!!!!!!!
Man, if they had only been a REALITY!!!!!
WOW!!!!!!!!!!!!!!!!!!!!
Thanks for sharing this!
['FLXIBLE"]
Posted: Sun Sep 21, 2025 5:41 pm Post subject: |
The color drawing looks like a modernized version of the original Twin articulated bus with front and rear axle steering and only up and down movement at the articulation.
The detailed drawing, though, has two axles in the trailing section. I wonder why? Was this bus going to be a conventional articulated that bends sideways and up and down at the articulation or like the original Twin articulated that only went up and down with the rear wheels steering. That would have meant both rear axles would have to steer.
Since it was never built, I guess it's just a theoretical question.
Posted: Sun Sep 21, 2025 5:45 pm Post subject: |
Personally, I always wondered if GM ever toyed with the idea of an articulated Old Look or a Fishbowl.....
["GMC"]
Posted: Sun Sep 21, 2025 6:29 pm Post subject: |
| Mississauga (Ontario) Transit had fishbowl articulateds. The front clip looked like those GM buses that were modernized fishbowls but the rest of the bus including the rear section looked like a fishbowl. I believe they had a number of these at one time. Scott Richards had one at one time and maybe still does.
Posted: Sun Sep 21, 2025 6:45 pm Post subject: |
| Cyberider wrote: | | Mississauga (Ontario) Transit had fishbowl articulateds. The front clip looked like those GM buses that were modernized fishbowls but the rest of the bus including the rear section looked like a fishbowl. I believe they had a number of these at one time. Scott Richards had one at one time and maybe still does. |
Cyberider:
I know the buses you are referring to.
I would have preferred that they kept the original "Fishbowl" front end...........
