Age: 72 Joined: 27 Feb 2013 Posts: 1236
Posted: Thu Oct 07, 2021 1:39 pm Post subject: Air Conditioned Demo |
This bus started life as a model TDH-5103, serial #001 in 1950 and it went to GM Engineering.
As so such the bus bus made the rounds as a demo, specially for and in the color scheme of San Francisco's Muni.
In 1958 it became a TDH-5105 serial EXP-305 when air conditioning was installed, as well as air suspension.
In this mode it made more rounds as a demo. The paint scheme used on this bus inspired the DC Transit administration to use it for their buses.
It was used by Fifth Avenue Coach on a variety of routes, here we see it on Queens Boulevard ready to turn into Roosevelt Avenue working on the route 15, Jackson Heights Line. The second view shows the rear of the bus in another New York location working for another route
After its demo tours the bus wound up with New Orleans Public Service. By then the rear door was changed to a push out door and the rear side engine vents were changed to the half moon shape.
137.38 KB |
9562 Time(s) |
148.47 KB |
9562 Time(s) |
Joined: 18 Dec 2007 Posts: 32868 Location: NEW JOISEY
Posted: Thu Oct 07, 2021 3:31 pm Post subject: |
MAGNIFICENT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WHAT A HUNK O' BUS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
(thanks for posting these excellent photos of a REAL bus!*!!)
*Here's a color photo of #3200, seen at 35th Avenue & 69th St. (note the MACK bringing up the rear!)
https://www.nycsubway.org/perl/show?156384
Last edited by NEW YORK OMNIBUS 2629 on Fri Oct 08, 2021 11:34 am; edited 1 time in total |
Age: 76 Joined: 24 Apr 2007 Posts: 1150
Posted: Fri Oct 08, 2021 11:25 am Post subject: Re: Air Conditioned Demo |
| MaBSTOA 15 wrote: | This bus started life as a model TDH-5103, serial #001 in 1950 and it went to GM Engineering.
After its demo tours the bus wound up with New Orleans Public Service. By then the rear door was changed to a push out door and the rear side engine vents were changed to the half moon shape. |
As a "yout" I grew up six blocks away from the picture. If you look in the background visible is a branch of Manufacturers Hanover Trust. I remember a teacher at JHS 125 telling the class that famed bank robber, Willie Sutton, making a withdrawal without having an account there.
