BrooklynBus
Age: 76 Joined: 19 Aug 2007 Posts: 138 Location: Brooklyn
Joined: 26 Mar 2011 Posts: 2749 Location: South Florida
Posted: Wed Feb 05, 2020 3:12 pm Post subject: Re: Sign the petition to oppose the elimination of bus stops |
| BrooklynBus wrote: | | https://www.change.org/p/mta-oppose-the-mta-s-plan-to-eliminate-bus-stops |
While I understand your point of view, I cannot support it...I believe that on my route, the stops are indeed too close together, and that coupled with the excessive stops often resulting in missing additional traffic signals, significantly slows my ride... |
| redacted duplicate post |
BrooklynBus
Posted: Wed Feb 05, 2020 5:05 pm Post subject: Re: Sign the petition to oppose the elimination of bus stops |
| traildriver wrote: | | BrooklynBus wrote: | | https://www.change.org/p/mta-oppose-the-mta-s-plan-to-eliminate-bus-stops |
Didn’t say they can’t remove some stops, but removing half of them is way too much. You can’t have some buses stopping every half mile or every mile without providing local service. Even stops every quarter mile are too far for some too walk because they have mobility issues. Are they all supposed to use Access a Ride? |
Posted: Wed Feb 05, 2020 11:14 pm Post subject: |
| Every four blocks instead of every two (or even every block in some cases), would be reasonable, I believe. I don't think walking two blocks is excessive for anyone, even if confined to a wheelchair. I agree that a half mile or more is excessive... |
