Age: 68 Joined: 17 Apr 2007 Posts: 1799 Location: Central NJ
Posted: Sat Aug 17, 2013 2:06 pm Post subject: |
I think it's time to plagiarize a page from the history of our business!
All double decked Fifth Avenue Coaches from a time before they moved the stairway inside to become a one man operation on the closed top Z's in 1930 had a completely separate driver compartment with its own access door.
This could easily be accomplished again today because of the manner in which revenue is collected and the fact that drivers really never have to have direct contact with passengers - and if they should need to answer a question it can be done by the use of electronic communication through a heavy glass partition.
I'm afraid that that may be the direction in which we may be heading!
Posted: Sat Aug 17, 2013 6:59 pm Post subject: |
| When I was in London in 2008, I rode double-deck Volvo buses on routes 9 and 10; these units were equipped with operator's compartments with full plexiglas shields. |
Tiny Tim
Age: 64 Joined: 20 Aug 2012 Posts: 97 Location: Cape Coral Fl
Posted: Sun Aug 18, 2013 8:31 am Post subject: |
| In the early 80's JBL tested out one that a driver designed. It made the drivers area into a small room. A couple of guys I know had a chance to use that bus for a shift and felt that it felt like a small closet. |
Hankg42
Age: 75 Joined: 19 Apr 2010 Posts: 94 Location: The Villages, FL
Posted: Mon Aug 19, 2013 11:14 am Post subject: |
| If it can be done for NYC taxi cabs, it certainly can (and should) be done for buses. |
Age: 78 Joined: 01 Feb 2011 Posts: 748 Location: St. Peters, Mo.
Posted: Tue Aug 20, 2013 12:46 am Post subject: |
| Hankg42 wrote: | | If it can be done for NYC taxi cabs, it certainly can (and should) be done for buses. |
Taxi drivers have a door to enter and exit their cab separate from the passenger section. Unless bus drivers have their own side door (similar to the old British Routemasters) I doubt this is workable as far as keeping them isolated from the passengers.
Posted: Tue Aug 20, 2013 1:52 am Post subject: |
Here's retired Fifth Avenue Coach #1220 when it was on display at the Southampton Automotive Museum back in the late fifties.
Note that all passengers, whether for the lower or upper level, entered from the rear and, while there was no front passenger door, there was a driver's entry at the wheel.
Had crime have been rampant in those days, it would have been very easy to have stretched a petition across the body just behind the driver.
I see nothing that would prevent the installation of a 'driver's booth' encased in heavy glass or other transparent material with the same driver access seen on #1220.
In this scenario, you would still have a front door and revenue collection equipment along with an electronic means to talk to the driver if necessary.
Photo from the Bob Wasche Collection
