Vintage Suffolk County Coach Buses
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
S-60 To Smith Haven Mall
PostPosted: Fri Nov 01, 2013 7:28 am    Post subject: Reply with quote
Made multiple updates to the list yesterday, since it was one day after I had made updates I just used the same post. (Which is why it says it was posted on 10/30 while the As Of date says 10/31.)
PostPosted: Fri Dec 13, 2013 5:20 pm    Post subject: Reply with quote
As of 12/13/13
*Some buses may not fit the word Vintage due to their age, let me know if they should be removed from the list, also I believe a age should be selected to designate a bus as vintage*
(Active Bus Companies on top, Disbanded Companies on bottom)
Alert Coach
19xx MCI MC-9: 3123-3124
19xx MCI: 3129-3130
Hampton Jitney Bus
19xx Eagle Model 15 or 20: 30
1993 Prevost H3-40: 47
1994 Prevost H3-40: 50
19xx Prevost H3-45: 63
1997 Prevost LeMirage XL: 92 (Ex Sunrise Coach)
1998 Prevost LeMirage XL: 93-94 (Ex Sunrise Coach)
1999 Prevost LeMirage XL: 95 (Ex-Sunrise Coach)
2000 Prevost H3-45: 96-97 (Ex Sunrise Coach)
2001 Prevost LeMirage XL II: 98-99 (Ex Sunrise Coach)
2002 GCA Freightliner: 100 (Ex Sunrise Coach)
2002 Prevost LeMirage XL II: 101 (Ex Sunrise Coach)
2003 Prevost LeMirage XL II: 102 (Ex Sunrise Coach)
2004 Prevost LeMirage XL II: 103 (Ex Sunrise Coach)
2004 Prevost H3-45: 104 (Ex Sunrise Coach, is in a Gold Paint Scheme)
2005 Prevost H3-45: 105 (Ex Sunrise Coach)
2006 Prevost Le Mirage XL II: 106 (Ex Sunrise Coach)
xxxx MCI F3500: 88
xxxx Prevost LeMirage XL-II: 90
xxxx Prevost Model X3-45 #80,84,86,89,91,98-99,101-103,106-107,112,117-119,121-122 (#91,112,117-118, and 121-122 are in the Ambassador Scheme, #113 has a side destination sign similar to MTA NYCT's Prevosts)
xxxx Prevost Model H3-45 #60,62-65,66-67,70-79,81,85,87,90,96-97,104-105,108,110-111,114-115,120,123-124 (#74 and #76 are wrapped)
xxxx Prevost H5-60: xxx
Sunrise Coaches Inc.
1954 GM PD-4104: 45 (Ex Monumental Tours of Baltimore, MD. Unknown number when run at Monumental Tours)
1964 GM PD-4106: 103
1981 Prevost LM-103: 300-301 (Both came in May of 1981?, but #300 was built before #301)
1997 Prevost LeMirage XL: 329 (Went to Hampton Jitney # 92)
1998 Prevost LeMirage XL: 331-332 (Went to Hampton Jitney # 93-94)
1999 Prevost LeMirage XL: 334 (Went to Hampton Jitney # 95)
2000 Prevost H3-45: 336-337 (Went to Hampton Jitney # 96-97)
2001 Prevost LeMirage XL II: 338-339 (Went to Hampton Jitney # 98-99)
2002 GCA Freightliner: 403 (Went to Hampton Jitney # 100)
2002 Prevost LeMirage XL II: 340 (Went to Hampton Jitney # 101)
2003 Prevost LeMirage XL II: 341 (Went to Hampton Jitney # 102)
2004 Prevost LeMirage XL II: 342 (Went to Hampton Jitney # 103)
2004 Prevost H3-45: 343 (Went to Hampton Jitney # 104, Has Gold and Blue Lettering)
2005 Prevost H3-45: 344 (Went to Hampton Jitney # 105)
2006 Prevost LeMirage XL II: 345 (Went to Hampton Jitney # 106)
North Fork Express/Hampton Express, Inc
1988 MCI 102A2: 13
[19xx MCI: 3,471,2001
19xx MCI 102-DL3: 9804
xxxx MCI D4500: 8
20xx MCI J4500: 2601-2602
Classic Coach
1999 MCI 102EL3: 2001
xxxx Provost Le Mirage XL-II: 2120
xxxx Provost: 2506-2508,2701-2704,2708,2711,2802
Hampton Luxury Liner (2009-Present owned by Classic Coach)
xxxx Provost: 2011,2706,2709,2711-2712 (#2706,2709 was branded for BoltBus, #2711 branded for 7Bus, #2709,2711 ex Classic Coach #2709,2711???)
2011 Provost X3-45: 2801,2803-2804 (#2803 was branded for BoltBus, #2803-2804 branded for 7Bus)
In Active Bus Companies
Coram Bus Service
1947 Flxible Clipper: 103
1974 GM P8M-4905A: 118
1975 GM P8M-4905A: 125
1976 GM P8M-4905A: 127
1977 GM P8M-4905A: 128
Inter County Motor Coach
1958 GM PD-4104: 120 (Sent to Lincoln Transit NJ)
1958 GM PD-4104: xxxx
1972 GM P8M-4905A: 290
1973 GM P8M-4905A: 434
1974 GM P8M-4905A: 330-332 (#330-331 came two buses before #332)
1975 GM P8M-4905A: 1776
1975 GM P8M-4905A: 1776B
1976 GM P8M-4905A: 446
1977 GM P8M-4905A: 445-444
1979 MCI-9: 602 (Sent to Oak Tree Bus Service as #77)
19xx -------: 615
Harran Transportation
[1954 Flxible VisiCoach: ????
1974 GMC P8M-4905A: 504-505 (#504 leased to NJ Transit #6920)
1976 GMC P8M-4905A: 506-507 (#507 leased to NJ Transit #6921)
1977 GMC P8M-4905A: 508,510 (#510 leased to NJ Transit #6922
1979 MCI-9: 511-512 (Leased to NJ Transit #6909-6910)
1979 GMC H8H-649: 514 (leased to NJ Transit #6923)
1980 MCI-9: 515-518,528-531 (#515-516 came first, then #517, then #518, then followed by #528-531, Leased to NJ Transit #6901-6908. 515 went to Private Transportation)
1981 MCI-9: 519,553,565 (#565 is now a bus for a church in Wyananch)
1982 Eagel Model 10: 536
1983 MCI-9: 569,573 (#573 went to Charter Bus Lines of British Columbia #204, then leased to Quick Coach Lines #204)
1989 Eagle Model 15: 600-605
xxxx Eagle Model xx: 523
xxxx MCI 96A2: 607
1998 Prevost H3-45: 815,819 (#819 Ex-Worldwide #745, Current Go Buses #9148, #815 Had Portrait of Twin Towers, Went to Horizon Bus Service)
xxxx Prevost xx-xx: xxx (Space Shuttle Paint scheme)
Long Island Airports Limousine Service
1976 GMC P8M-4905A: #703
PostPosted: Sat Jan 04, 2014 10:13 pm    Post subject: Reply with quote
As of 1/4/14
Alert Coach
19xx MCI: 3129-3130
Hampton Jitney Bus
xxxx MCI F3500: 88
1988 MCI 102A2: 13
xxxx MCI D4500: 8
Classic Coach
Coram Bus Service
1975 GM P8M-4905A: 1776-1776B
19xx -------: 615
19xx MCI: 881
xxxx MCI 96A2: 607
Last edited by S-60 To Smith Haven Mall on Sun Jan 05, 2014 5:40 pm; edited 1 time in total
PostPosted: Sun Jan 05, 2014 3:02 am    Post subject: Reply with quote
S-60 To Smith Haven Mall wrote;
"Some buses may not fit the word Vintage due to their age, let me know if they should be removed from the list, also I believe an age should be selected to designate a bus as vintage"
In antique parlance an item, regardless of what it is, is considered a relic at 50 years old and the New York State Motor Vehicle Bureau (DMV) looks at any vehicle as historic at the age of 30.
However, I think that with buses the rule of thumb should be that they are considered 'vintage' once every one of a particular ilk known to exist has been retired from revenue service.
In the good old days of 'real' buses that would have averaged at about twenty five to thirty years as opposed to today's 'styrofoam' fire traps that are usually gone from the scene in a matter of little more than a decade (the GM RTS might just be the one exception to the rule).
Many regards,
PostPosted: Sun Jan 05, 2014 9:34 am    Post subject: Reply with quote
"Styrofoam" fire traps... Love the description!
These new buses all look alike... One knew the difference between a GM and a Mack; a Flxible; a Twin Coach, etc... and not just bus enthusiasts!
PostPosted: Sun Jan 05, 2014 2:23 pm    Post subject: Reply with quote
MaBSTOA 15,
I call them 'firetraps' because only seconds after a fire starts in the engine compartment (and that's where more than 90% of bus fires begin) the entire bus becomes an inferno and within minutes all that's left is a sleleton.
I can't believe that these engine rooms don't have adequate fire walls to stem incursions into the passenger cabins.
Maybe someone will wake up to this problem some day!
PostPosted: Sun Feb 09, 2014 5:01 pm    Post subject: Reply with quote
As of 2/9/14
Hampton Jitney
19xx Unkown: 28
19xx Prevost H5-60: xxx
Coram Bus Service
19xx -------: 615
19xx MCI: 881
1977 GMC P8M-4905A: 508,510 (#510 leased to NJ Transit #6922)
1980 MCI-9: 515-518,528-531 (#515-516 came first, then #517, then #518, then followed by #528-531, Leased to NJ Transit #6901-6908. #515 went to Private Transportation)
xxxx MCI 96A2: 607
PostPosted: Tue Feb 11, 2014 11:26 am    Post subject: Reply with quote
As of 2/11/14
Hampton Jitney
19xx Setra: ??-28
1989 Prevost H5-60: xxx (Sold to Venture Tours in 1997)
Coram Bus Service
19xx -------: 615
19xx MCI: 881
xxxx MCI 96A2: 607
PostPosted: Thu Feb 13, 2014 7:20 pm    Post subject: Reply with quote
As of 2/13/14
Hampton Jitney
1985 Setra: ??-28
Coram Bus Service
1977 GM P8M-4905A: 444-445 (445 came before 444)
19xx -------: 615
19xx MCI: 881
1982 Eagel Model 10: 536 (Brought by Angie Carpenter's campaign for her 2011 run for Suffolk County Executive)
1985 Eagle AE-10: ??? (Ex Greyhound #7945, Exx Trailways Commuter Transit #8491)
xxxx MCI 96A2: 607
PostPosted: Thu Feb 13, 2014 8:41 pm    Post subject: Reply with quote
IIRC didn't LIALS run a bunch of Eagles at one time? I seem to remember that my son rode one on a school trip Albany during the 90-91 school year.
PostPosted: Thu Feb 13, 2014 9:15 pm    Post subject: Reply with quote
I personally know very little about LIAS, other then that they were contracted by the student government of SUNY Stony brook to run a route from Port Jefferson to Smith Haven Mall Via the college with stops at the local supermarket and what is today Coventry Mall in the 70's, and that Coram Bus Service got mad at because the Student Government said they talked to all the bus companies in the phone book but never contacted them and also the Student Government route cost less then Coram's Port Jefferson-Smith Haven Mall route. Coram Bus Service ended up with the route anyway a few years later. Also I know that the company was listed as a contractor for Suffolk Transit in an 1983 audit of the system. If I remember correctly it was said that they were one of the companies the county overpaid for service.
I wouldn't be surprised though if LIAS did have Eagles, since it seems that a few companies that had coach buses had Eagles at some point.
PostPosted: Fri Feb 14, 2014 1:18 pm    Post subject: Reply with quote
LIALS started out as an airport taxi service on LI. IIRC they ran extended (stretched) Checker vehicles. I think they were called Aerocaches by the manufacturer. I think they ran routes along the south shore, mid-island and north shore.
They would rendezvous on the LIE service road at Little Neck Parkway where you might have to change vehicles depending on which airport you were headed to. I think there was a stop e/b on the s/s of the LIE also at Little Neck.
They then branched into charter service with their Eagles and had their garage on Newton Court in Hauppague. They were owned by a family named Stuart or Stewart.
Then I started seeing a 718 number on their buses along with their 631 number. A check on the internet showed that they were operating out of Brooklyn, bought by some Russians.
That's all I know
PostPosted: Fri Feb 14, 2014 3:47 pm    Post subject: Reply with quote
I figured out why I couldn't find anything on LIALS was because their legal name is Long Island Limousine Service Corp. There are 3 listed entries on the New York State Corporation and Business Entity Database.
Entry #1 was for Long Island Limousine Service which was started in 1972 and had it's name changed in 1979 to Stuart's Limo Corp. Inactive in 1981
Entry #2 was for Long Island Service Corp started the same day #1 had it's name changed. The last name of the person on the DOS Process was Stewart. Inactive in 2009
Entry #3 was for Long Island Service Corp started on the same day that #2 became Inactive. This one is currently active, and is based in Hauppauge.
Tiny Tim
PostPosted: Fri Feb 14, 2014 8:35 pm    Post subject: Reply with quote
I recall seeing LIALS in the early 80's. And they Port went after them claiming they owed money to them. I don't know if it went to court or what the outcome was but all of a sudden they were gone for a while then I would see them once in a while.
PostPosted: Thu Mar 20, 2014 3:37 pm    Post subject: Reply with quote
As of 3/20/14
Hampton Jitney
1985 Setra: ??-28
Coram Bus Service
19xx GM PD-4903: 362
19xx -------: 615
19xx MCI: 881
xxxx MCI 96A2: 607
1998 Prevost H3-45: 815-81x,819 (#819 Ex-Worldwide #745, Current Go Buses #9148, #815-81x Had Portrait of Twin Towers, Went to Horizon Bus Service #120-121)
Page 4 of 10
