![BusTalk Forum Index](templates/subSilver/images/logo_phpBB.gif) |
![](images/avatars/63770683248e1440240ca5.jpg)
Posted: Fri Nov 05, 2010 6:43 pm Post subject: 'BIG TROUBLE FOR AIRBUS' |
'JET ENGINE FAILURE CAUSES WORRY FOR MANUFACTURER'
By JAD MOUAWAD
Published: November 4, 2010 The New York Times
The blowout of an engine on Qantas Flight 32 on Thursday was the latest in a series of problems involving Rolls-Royce engines and analysts said it raised serious questions about the company’s ability to develop the engines for the newest generation of commercial and military airplanes.
The damaged engine of the Qantas plane that made an emergency landing on Thursday at Changi Airport in Singapore.
Related
The episode, involving a Qantas A380 jetliner carrying more than 450 people, was particularly alarming because it occurred on the world’s largest passenger plane and a flagship program for Airbus, a unit of the European Aeronautic Defense and Space Company, or EADS.
Rolls-Royce of London, which is a separate company from the carmaker owned by BMW, is also developing an engine for Boeing’s latest aircraft, the 787 Dreamliner. Problems with that engine have contributed to the program’s delays.
“This is extremely worrying for Rolls-Royce,” said Phil Abbott, editor of Aircraft Engines, a London-based industry newsletter. “There is no such thing as a shoddy engine maker. But the moment engines fly to bits, no one wants to fly them anymore.”
The pressure on Rolls-Royce intensified on Friday when Qantas’s CEO, Alan Joyce, said the mid-air engine failure on Flight 32 may have been caused by material failure or a design problem with the engines. Mr. Joyce said it was still too early to determine a cause for the failure but he rejected concerns from a labor union that it may have been caused by insufficient maintenance, a responsibility of the airline.
“We believe this is probably, most likely, a material failure or some sort of design issue,” Mr. Joyce said at a news conference in Sydney, Australia. “We don’t believe this is related to maintenance in any way.”
Passengers from Flight 32 were being flown to Australia on Friday, and were expected to arrive in Sydney in the evening.
At his new conference, Mr. Joyce said Qantas, Airbus and Rolls-Royce were examining the engines on all of the airline’s A380s, a check expected to be completed this weekend. The airline’s fleet of six A380s remained grounded on Friday, but Mr. Joyce said that if no problems are found the A380s would resume flying, he said.
In at least two previous cases during the past year, two A380 airplanes with Trent 900 engines from Rolls-Royce were forced to land after an engine failure. In August, a Rolls-Royce Trent 1000 test engine developed for Boeing blew up during a ground test.
Rolls-Royce has also faced problems with its military engines, where it has teamed with General Electric to build an alternate engine for the F-35 Joint Strike Fighter. Both companies are battling to keep the Pentagon from canceling the project. They disclosed in late September that one of their test engines had experienced an anomaly that damaged the airfoils. Pratt & Whitney has the main contract to build engines for the fighter, and the government sales could reach $100 billion over 25 years.
Modern engines are designed to contain a blowout inside the engine’s casing so that broken parts are not sprayed at high speed into the fuselage or the wings, where the fuel tanks are located. But in the case of Flight 32, parts of the engine were blown away and appeared to rupture the wing. An Airbus spokesman in France said it was the first uncontained engine failure and the most serious problem experienced by the A380 since it entered service in 2007.
The double-decker A380 airplanes fly with four engines, which are developed either by Rolls-Royce or Engine Alliance, a joint venture between G.E. and Pratt. All the engine failures on A380s have so far involved Roll-Royce engines, analysts said.
In a statement, the company said it was cooperating with investigators. “This is at a very early stage, and it would be inappropriate to draw any conclusions at this time.”
Robert W. Mann Jr., an aviation industry expert in Port Washington, N.Y., said that the concern with Flight 32 was that the debris was not contained by the engine casing. “An uncontained failure is the most serious because it causes collateral damage,” he said.
There are 37 A380s in service, 20 with the Rolls-Royce Trent 900 engine. Three airlines operate with the Trent 900: Qantas, which has six; Lufthansa, three; and Singapore Airlines, 11.
Emirates Airline, which operates 13 A380s, and Air France, which has four in service, use the GP7200 engine developed by the G.E.-Pratt joint venture.
Rolls-Royce’s problems also raise questions about the newest plane being developed by Airbus, the A350, made out of composite material and meant to compete with the 787 from Boeing. Unlike most aircraft programs — including the A380 and the 787, which are built with two engine options — the A350 will be configured with only one engine, the Rolls-Royce Trent XWB.
While the A380 program has not been a big commercial success for Airbus, the company has much more at stake with the A350. Airbus has 234 orders for the A380, but it already has 573 orders for the A350, which it expects to put into service in 2013.
“You design an aircraft around an engine, and the aircraft’s performance depends upon its engine,” said Richard L. Aboulafia, an analyst at the Teal Group, a consulting firm in Fairfax, Va. “The real issue is Rolls-Royce’s reputation as a development company. They promised an awful lot with the A350. There is a lot riding on that engine and on that plane, whose performance is entirely dependent on Rolls-Royce.”
Airbus declined to comment about the impact of Thursday’s episode on the development of the A350.
One expert suggested on Thursday that Rolls-Royce might have stretched technological limits with its latest Trent engines in the race to provide better efficiency. “I think it is possible that one of the problems Rolls-Royce is experiencing over all is that they may have lost a little bit of margin in the design of their engines,” said Hans Weber, the president of Tecop International, an aviation consulting firm in San Diego. “We are pushing harder to the limits because we are forced to increase the efficiency.”
Christopher Drew contributed reporting.
Photo by Wong May for E/Associated Press
![](http://i198.photobucket.com/albums/aa193/MISTERLINSKY/JET380.jpg) |
![](templates/subSilver/images/spacer.gif) |
shortlineMCI
Age: 54 Joined: 07 May 2007 Posts: 241
Posted: Tue Nov 09, 2010 10:59 am Post subject: |
I think it's going to be a very long time before I fly anywhere. These crashes, and incidents and accidents seem to be happening once or twice a month now.
Yea, I know..I can ask any veteran flyer and they'll tell me I"ve flown for blah blah times and nothing ever happened.
Well, my answer to that is..yes well..that's what these poor passengers have said as well.
I'm sticking to buses. |
Posted: Tue Nov 09, 2010 2:28 pm Post subject: |
Ken,
Now you tell me this when I'm already booked for New York on the 22nd.!
I'll tell you this; after a 'cardboard' tail brought down an American Airlines AirBus A300 over Rockaway only days after 9/11 (although it had nothing to do with terrorism) I either fly Boeing or I walk!
What really scares me about this most recent A380 engine blow up was that it wasn't contained and fragments flew like missiles with fully loaded wing tanks only inches away!
It's nothing short of a miracle that those 400 some odd people weren't killed!
Remember the Concorde that was brought down by one small piece of cowling tie-down left on the runway from another plane?
Lots to think about.
Age: 74 Joined: 24 Apr 2007 Posts: 1150
Posted: Tue Nov 09, 2010 9:40 pm Post subject: |
WCA:
I guess then that Jet Blue ain't for you since they only fly the A320. Waddya expect when the French built something ???????
ECA |
Posted: Wed Nov 10, 2010 9:20 am Post subject: |
Hmmmm...? When in doubt, fly S W A all the way, with it proved and zealous dedication to the Boeing 737.
If it doesn't go there, why go?
(BTW. I'm "tuned in" on what it does with its Air Trans buy. I'm not a mind reader, but I can anticipate some
equipment up for immediate sale. The thought of S W A running into Bahamas is a bit amusing, though)...
....................Vern.......................... |
Posted: Wed Nov 10, 2010 1:56 pm Post subject: |
Vern,
That would be a great slogan for any airline; "if we don't go there - why go?"
I have to remember that one.
P.S.; wait until Lufthansa buys S W A and starts flying 380's to the Bahamas - can you just imagine that? (only kidding).
GBL Rebel Moderator
![](images/avatars/1783524387642239d906ead.jpg)
Joined: 16 Apr 2007 Posts: 608 Location: Long Island, N.Y.
Posted: Thu Nov 11, 2010 9:54 am Post subject: |
I had an agent get grumpy when I asked what kind of plane years ago while making a resevation. I told her I don't fly 727's, MD80's or Airbus. She acted like I had passed a rude comment to her. Almost walked off a plane 2 years ago because it was an Airbus. |
shortlineMCI
Posted: Wed Nov 17, 2010 8:49 pm Post subject: |
Actually..what is on my bucket list is to fly a (well, not FLY, but ride) DC-3. I don't even care where it's going. I just want a ride in a genuine DC-3.
Just thought I share that. |
Posted: Thu Nov 18, 2010 2:16 am Post subject: |
Ken,
Here's one with an air conditioned 4507 thrown in!
Enjoy,
![](http://i198.photobucket.com/albums/aa193/MISTERLINSKY/B9GEqHWkKGrHqUOKpwEyjC5UEgBM4ymRKtg_3.jpg) |
