Age: 74 Joined: 24 Apr 2007 Posts: 1150
Posted: Wed Jun 25, 2008 10:27 am Post subject: Suffolk Transit Bus # 9614 still alive |
Saw this bus southbound on NY Avenue yesterday at 4:45 PM, near Reinwald's (yummy,yummy) bakery working on the S-1.
I left the doctors office with my wife at about 5:30PM and saw another older ST bus (based the blue roof livery) heading N/B turning into the Big H shoppping center. Couldn't get close enough to see the number.
Guess EBT is doing a good job to keep these oldies on the road. |
The Port of Authority
Posted: Wed Jun 25, 2008 6:19 pm Post subject: |
I've seen a number of 96xx-series Gilligs during my recent trips to Suffolk, most of which are painted in the new paint scheme. Although they're somewhat rare compared to the new 50xx Gilligs that seem to dominate the system. |
Pineywoodsbus
Posted: Fri Jun 27, 2008 12:21 am Post subject: |
You can see these "oldies" also on the 5A, 6A, 8A, and the S59.
They seem to be used on mostly "feeder" routes.
The 5A is almost exclusively these older buses, though I did see an Orion last week, a rarity for the 5A. |
S-60 To Smith Haven Mall
Joined: 29 Nov 2007 Posts: 1757 Location: Suffolk County, NY
Posted: Mon Jul 14, 2008 10:48 pm Post subject: |
Pineywoodsbus wrote: | You can see these "oldies" also on the 5A, 6A, 8A, and the S59.
7D/E and 6B. but all the 9600 buses aren't all repainted. CBS's aren't, only 9650 and 9655 from Suffolk Bus Corp is (that i know of), 9605 from Sunrise coach isn't repainted, but 9647 and 9642 are repainted and last time i saw 9601 from Inter-County wasn't repainted.
and last time i checked the S59 wasn't a feeder route. |
LLE Rebel
Posted: Tue Jul 15, 2008 10:15 pm Post subject: |
Interesting... I wonder who pays for the buses to get repainted... the companies or the county??? |
Posted: Tue Jul 15, 2008 10:47 pm Post subject: |
LLE Rebel wrote: | Interesting... I wonder who pays for the buses to get repainted... the companies or the county??? |
repaint are prob the companies since that would fall under physical maintenance,and would explain why 9600 from Inter County Looks horrible in the front. put the way the buses are painted when they order it would be the County |
Pineywoodsbus
Posted: Thu Jul 17, 2008 9:47 pm Post subject: |
I rode 9647 on the S92 yesterday...I knew this bus sounded different than the others on the 92, it had that "Suffolk Bus Corp" axle noise and ads for Suffolk Bus corp in the interior.
Ran pretty good though compared to the other older Gilligs with the S50 engine at Sunrise. Also saw 5042 on the 10B in East Hampton....usually they have one of the older Gilligs on that route.
Someone on the radio who was on the S90 said their bus sounded bad, I know 5041 is on that route.
HJ seems to have drivers doing different runs at different times of the week. I had someone on the 10C yesterday who was on the S90 on Friday. They wear the green HJ shirts instead of an ST uniform..usually. |
Posted: Thu Jul 17, 2008 10:30 pm Post subject: |
Pineywoodsbus wrote: | I rode 9647 on the S92 yesterday...I knew this bus sounded different than the others on the 92, it had that "Suffolk Bus Corp" axle noise and ads for Suffolk Bus corp in the interior.
i guess 9647 was pressed into service as soon as it got to Sunrise, from what u said they have in the inside. i guess nobody metioned that they have ads that need to be taken down. i find it bad that they still have Suffolk Bus Corp stuff up.
5041 is bad, last time i heard about that bus, it was leaking something and when told about it the driver denied it.
well i don't know about HJ or Sunrise, but the time when u see most drivers switch just past. i know i saw a driver on the S66 two weeks ago that use to drive the 7:00 S61 out of Port Jefferson |
Pineywoodsbus
Posted: Sat Jul 19, 2008 12:08 am Post subject: |
5041 always has problems, especially in winter they have trouble getting it started. It doesn't run that good either, but it still has alot more "pep" to it than most LI Buses. I did notice when I rode it last Friday on the 90 there was no a/c even though it was 85F outside.
One thing maybe you can answer is one time I noticed on a cold winter morning when the 6A pulled into Ronkonkoma and the driver took a break, he shut off the engine but it looked like a little motor was going because I heard something and steam was coming out of a small pipe. Is it possible some Suffolk buses have heaters on the buses to keep the engine warm? |
Posted: Sat Jul 19, 2008 7:29 pm Post subject: |
Pineywoodsbus wrote: | 5041 always has problems, especially in winter they have trouble getting it started. It doesn't run that good either, but it still has alot more "pep" to it than most LI Buses. I did notice when I rode it last Friday on the 90 there was no a/c even though it was 85F outside.
i wouldn't know if they have heaters, but what u descibe sounds to me like the driver shut off a hot engine on a cold day and it made steam. other then that i wouldn't know what it could be |
Posted: Fri Feb 26, 2010 12:06 am Post subject: |
"oldie" 9725 which was on the S59 last week was painted in the scheme.
and i was wrong, apparently the 6B now uses Orions, as i seen two last week. 9936 and another unidentified one. at the time i thought it was the same bus, but when i looked at the 6B schedule i noticed that 9936 couldn't possibly been the 6B i saw earlier in the day as it was suppose to be at the other end of the route at the time i saw the other bus on the route. |
