MSBA/LIB Roster
PostPosted: Wed May 16, 2007 8:44 pm    Post subject: MSBA/LIB Roster Reply with quote
I had found the following posted at Bus Rosters On The Web (it dates back to 2001):
Metropolitan Suburban Bus Authority (to '94)
MTA Long Island Bus ('94 on)
New York, NY
version 5.0.0
All time roster
Number Builder Model Serial # Built Notes
72 - 74 GM TDH-5302 621 - 623 1962 ex- Jerusalem Av off roster by 1993
75 - 78 GM TDH-5304 262 - 265 1963 ex- Jerusalem Av off roster by 1993
82 - 83 GM TDH-5304 1614 - 1615 1967 ex- Jerusalem Av off roster by 1993
100 - 102 GMC T6H-5306A 031 - 033 1968 ex-Schenck, off roster by 1993
103 - 104 GMC S8M-5304A 103 - 104 1973 off roster by 1993
105 -112 GMC T6H-5310A 107, 04, 00, 05, 03, 02, 06, 01 1973 off roster by 1993
113 - 120 GMC S8H-5304A 067, 071, 065-066, 072, 068-070 1973 off roster by 1993
121 - 122 GMC S8M-5304A 115-116 '73
100(II) - 124(II) Orion 05.501 S6032154, 2191, 2194, 2195, 2197 - 2199, 2201 - 2202, 2204 - 2209, 2212 - 2221 1996 CNG powered
123 -1 26 GM TDH-4517 1007 - 1010 1961 ex Rockville Centre off roster by 1993
125(II) - 130(II) Orion 05.501 see above 1996 re # from 106 - 108, 114, 118, 120 soon after delivery CNG powered
127 - 128 GM TDH-4519 705 - 706 1965 ex Rockville Centre off roster by 1993
131 - 142 Orion 05.501 T6032893,2984-2994 1996 CNG powered
143-245 Orion 05.501 V6032995 - 3024, 3026 - 3054, 3056 - 3070, 3186 - 3214 1997 CNG powered
150 GM TDH-5302 335 1961 ex Rockville Centre off roster by 1993
151 - 154 GMC TDH-5304 1613, 1564, 1075, 1565 1966 ex-RVC Bus off roster by 1993
155 - 156 GMC T8H-5306A 391-392 1971 ex-RVC Bus off roster by 1993
157 GM TDH-5304 1048 1966 ex Rockville Centre off roster by 1993
158 - 159 GM TDH-5302 332, 334 1963 ex Schenk 150, 152 off roster by 1993
160 - 162 GM TDH-5304 1043 - 1045 1966 ex Schenk 153 - 155 off roster by 1993
207 - 211 GM TDH-4517 942-946 1961 ex Stage Coach off roster by 1993
214 GM T6H-5306 075 1968 ex Stage Coach off roster by 1993
215 GM T6H-5306 281 1969 ex Stage Coach off roster by 1993
246-287 Orion V 1998 CNG
288-358(II) Orion V 8/2000 CNG
300-305 GM TDH-4519 326 - 331 1964 ex Schenck off roster by 1993
301(II) Neoplan "Lit'l Bus" FL013120 1985 ex Avis Rent-a-car off roster by 1993
302(II) - 304(II) Neoplan "Lit'l Bus" GH013429, 3425, 3423 1986 ex Avis Rent-a-car off roster by 1993
305(II) Neoplan "Lit'l Bus" FL013117 1985 ex Avis Rent-a-car off roster by 1993
306 GM TDH-4517 093 1960 ex Schenk off roster by 1993
307 GM TDH-4517 940 1961 ex Schenk off roster by 1993
316 GM TDH-4517 498 1960 ex Utility Lines off roster by 1993
318 GM TDH-4517 1006 1961 ex Utility Lines off roster by 1993
321 GM TDH-5302 582 1962 ex Utility Lines off roster by 1993
322 - 323 GM TDH-4517 1493-1494 1962 ex Utility Lines off roster by 1993
325 GM TDH-4519 058 1963 ex Utility Lines off roster by 1993
327 GM TDH-4519 708 1965 ex Utility Lines off roster by 1993
328 - 329 GM T6H-5306 076 - 077 1968 ex Utility Lines off roster by 1993
330 - 331 GM T6H-5306 204 - 205 1969 ex Utility Lines off roster by 1993
332 - 333 GM T8H-5306A 258 - 259 1971 ex Utility Lines off roster by 1993
350 - 399 Flx 53102-6-1 ex NYCTA (Note 1) Leased from NYCTA,
off roster by 1993
404 - 407 GM TDH-5302 345 - 348 1961 ex-Hempstead off roster by 1993
408 - 411 GM TDH-4517 1309 - 1312 1961 ex-Hempstead off roster by 1993
412 - 413 GM TDH-5302 277 - 278 1960 ex-Hempstead off roster by 1993
414 - 415 GM TDH-5302 626 - 627 1962 ex-Hempstead off roster by 1993
416 - 419 GM TDH-5304 107 - 110 1963 ex-Hempstead off roster by 1993
420 - 423 GM TDH-5304 497 - 500 1964 ex-Hempstead off roster by 1993
424 - 427 GMC TDH-5304 1080 - 1083 1966 ex-Hempstead off roster by 1993
428-431 GMC T6H-5306A 040-043 1968 ex-Hempstead off roster by 1993
432-439 FLX 111CC-D51 54483 - 54490 1970 ex-Hempstead off roster by 1993
441 FLX 111CC-D51 54492 1970 ex-Hempstead off roster by 1993
443-455 FLX 111CC-D51 54494 - 54506 1970 ex-Hempstead off roster by 1993 except 454; 454 by 1994
456 GM TDH-5302 753 '62 ex-Schenck 408 off roster by 1993
457 - 466 GM TDH-5302 041 - 050 '60 ex-Schenck 410 - 419 off roster by 1993
467 - 470 GM TDH-5302 411 - 414 '61 ex-Schenck 420 - 423 off roster by 1993
471 - 474 GM TDH-5302 443, 445, 446, 581 '62 ex Shenck 424, 426 - 428 off roster by 1993
475 - 478 GM TDH-5304 121 - 124 '63 Schenck 429 - 432 off roster by 1993
479 - 488 GMC TDH-5304 1516 - 1520, 2033 - 2037 1967 ex-Schenck 433 - 442 off roster by 1993
489 - 493 GMC T6H-5306 198 - 202 1969 ex-Schenck 443 - 447 off roster by 1993
494 - 495 GM TDH-5304 486, 382 '64 ex-Schenck 409, 606 off roster by 1993
496 GM TDH-5304 333 '63 ex-Schenck 151 off roster by 1993
500 - 506 GM TDH-5303 '65 MASBSTOA 6483, 6485, 6486, 6493, 6582, 6688, 6689 Leased from MASBSTOA, off roster by 1993
500(II) - 519 Gillig 35102TB6V92T J1082061 - J1082080 1988
507 - 511 FLX 111CC-D51 '70 MABSTOA 4600, 4688, 4670, 406, 4607 Leased from MABSTOA, off roster by 1993
520 - 561 Gillig 40102TB6V92T J1082018 - J1082117, J1082227 - J1082231 1988 out of service by 2000
564 GM TDH-4512 1683 '56 ex-Bee Line off roster by 1993
565 GM TDH-4517 069 '60 ex-Bee Line off roster by 1993
566 - 570 GM TDH-4517 1280 - 1284 '61 ex-Bee Line off roster by 1993
571-580 GM TDH-5301 '61 NYCTA 1093, 1059, 1086, 1017, 1057, 1070, 1081, 1055, 1023, 1108 Leased from NYCTA, off roster by 1993
579 - 599 Orion 05.501 L6030091 - L6030111 1990
600 - 602 GM TDH-5302 578 - 580 '62 ex Schenck off roster by 1993
600(II) - 656(II) Orion 05.501 Note 2 1991
603 - 605 GM TDH-5304 379 - 381 '64 ex Schenck off roster by 1993
610 - 614 GM TDH-5106 1333 - 1336 '57 ex-Bee Line off roster by 1993
610 - 614 GM TDH-5106 1365 - 1369 '58 ex-Bee Line off roster by 1993
615 - 619 GM TDH-5106 1600 - 1603 '59 ex-Bee Line off roster by 1993
620 - 621 GM TDH-5304 383 - 384 '64 ex-Schenck 607 - 608 off roster by 1993
622 - 625 GMC T6H-5306A 027 - 030 1968 ex-Schenck 609 - 612 off roster by 1993
626 - 634 GM TDH-5302 336 - 344 '61 ex-Bee Line off roster by 1993
635 - 644 GM TDH-5302 583 - 592 '62 ex-Bee Line off roster by 1993
645 - 649 GM TDH-5304 076 - 080 '63 ex-Bee Line off roster by 1993
650 - 659 GM TDH-5304 346 - 350, 335 - 339 '64 ex-Bee Line off roster by 1993
657(II) - 666(II) Orion 05.501 Note 3 1992
660 - 668 GM TDH-5304 725 - 729, 957 - 960 '65 ex-Bee Line off roster by 1993
669 FLX 111CC-D51 54511 1970 ex-Stage Coach 665 off roster by 1994
670 - 674 GM TDH-5304 1038-1042 '66 ex-Bee Line off roster by 1993
675 - 684 GMD TDH-5304 1603 - 1612 1967 ex-Bee Line off roster by 1993
685 - 693 GMD T6H-5306 001 - 004, 276 - 280 1968 ex-Bee Line off roster by 1993
694 - 698 GMD T6H-5306A 009, 034 - 037 1968 ex-Bee Line off roster by 1993
699 FLX 111CC-D51 54512 '70 Stage Coach 666 off roster by 1993
700 - 701 FLX FD6V401-7 35021 - 35022 1964 ex-Bee Line off roster by 1993
700(II) Orion 02.502 L6005506 1990 ex demo
701(II) - 705(II) Orion 02.501 S600588 - 5892 1995 CNG powereed,
note: 702 damged in delivery, to Burlington Transit 9784 (ONT), 703 r# 706 soon after delvery
702 GM SDM-5302 968 '67 ex-Bee Line off roster by 1993
703 GM SDM-5302 686 '66 ex-Bee Line off roster by 1993
704-705 FLX 111CC-D51 54513 - 54514 1970 ex Stage Coach 667-668 off roster by 1993
706 Orion 02.501 S600590 1995 ex-703(II)
707-708 Thomas School Bus S1130623 - 0624 '95
709-710 Thomas School Bus T1140696 - 0696 '96
711 Orion 02.501 S6005943 '96
712-714 FLX 111CC-D51 54508 - 54510 1970 ex-Schenck off roster by 1993
713 Thomas School Bus T1140697 '96
715-717 FLX 111CC-D51 54515 - 54517 1970 ex-Schenck off roster by 1993
718 FLX 111CC-D51 54507 1970 ex-Schenck 711 off roster by 1993
750-799 Flx 53102-8-1 93548 - 93597 1981 out of service by 2000
800-849 GMC T6H-5308A 223 - 272 1974 off roster
850-902 FLX 53096-8-1 63759 - 63812 1978 off roster
925-999 Flx 53096-8-1 93598 - 93672 1978 off roster
1000 GM TDH-5302 581 '62 ex 474 cut down to 30'
PA1001 - PA1033 Flx 40102-6T DE095878 - 5910, 6115 1984-85 out of service by 2000
2000 - 2004 Ford E350, Van
2005 - 2042 Ford E350, Van
3000 - 3007 Ford E350, Van
Data from Jeffrey Kay; transcribed by Alan Gryfe updated by Anita Persaud, Steve Hoskins, Andre Kristopans & Troy Bellamy.
last updated 4/21/01
This page brought to you by: A. J. Reinschmidt
Your help is needed!
Rosters are based on dated information. No matter how current they were when they were published, things change. New buses are acquired, and old buses sold or renumbered.
If you can provide any additional information or corrections to the rosters or delivery lists please let me know. Also if you can provide rosters of your local properties I'd be glad to post them. With your help we can make this the place for bus roster information.
My e-mail address is: buslist@geocities.com
Notes:
Note 1 :
NYCTA fleet numbers for 350 - 399 were:
7325, 7188, 7160, 7036, 7914, 770s, 7314, 7358, 7313, 7173, 7030, 7130, 7789, 7348, 7844, 7026, 7830, 7193, 7861, 7328, 7137, 7187, 7886, 7151, 7194, 7733, 7902, 7903, 7712, 7872, 7883, 7538, 7593, 7882, 7574, 7888, 7524, 7038, 7881, 7916, 7934, 7318, 7168, 7892, 7190, 7104, 7066, 7890, 7569, 7062
Note 2:
Serials for 600 - 656 are:
M6030563, M6030598, M6030600-M6030601, M6030603, M6030605-M6030606, M6030608, M6030610-M6030611, M6030613, M6030615-M6030616, M6030618, M6030630-M6030631, M6030633, M6030635, M6030638, M6030640, M6030643, M6030645-M6030646, M6030648, M6030650-M6030651, M6040653, M6030655-M6030656, M6030658, M6030660-M6030661, M6030663, M6030665-M6030666, M6030670-M6030671, M6030703-M6030706, M6030708-M6030710, M6030712, M6030714-M6030717, M6030719, M6030721-M6030724, M6030726-M6030727.
Note 3:
Serials for 656 - 666 are:
N6031169, N1031222-N1031223, N1031231-N1031232, N1031237, N6031251.
