'Another 60 BRT Story'
Goto page 1, 2  Next
Post new topic   Reply to topic    BusTalk Forum Index -> Surface Transit - Western United States
PostPosted: Mon Oct 15, 2007 11:49 pm    Post subject: 'Another 60 BRT Story' Reply with quote
On my usual homebound run from the office I found myself waiting for a light on Wilshire Boulevard at San Vicente in Beverly Hills this afternoon.
Bopping along at a pretty good clip on San Vicente were two Nabi 60 BRT's signed for route 920 - 'Not In Service', and probably heading for the Transit Center at Pico Boulevard.
You'll notice that I used the term 'bopping' because that's exactly what they were doing with their rear units actually bouncing up and down!
I would have to say that passengers riding in these rear sections could well suffer a bit of nausea to say the least.
Now I know what the LACMTA driver that I met a few weeks ago meant when he told me that there were plenty of suspension troubles with these buses!
According to the same source, Nabi is doing very little to fix the problem.
Photo below thanks to BleuMCO and borrowed for educational purposes only to illustrate the equipment mentioned.
Mr. Linsky - Green Bus Lines, Jamaica, NY
PostPosted: Tue Oct 16, 2007 8:56 am    Post subject: Reply with quote
Kind of reinforces our opinions about the new buses. All show and no go. Twisted Evil
AZNABIman
PostPosted: Mon Nov 19, 2007 10:54 pm    Post subject: Reply with quote
Chicago also has been having major problems with the suspensions on their NABI artics. Somehow I think that this could be a major design flaw. I've been on New Flyer D60LFs and while they are more "bouncy" than regular 40 foot buses they certainly aren't bad.
PostPosted: Mon Nov 19, 2007 11:42 pm    Post subject: Reply with quote
AZNABIman,
Personally, I think LACMTA is putting WAY too many eggs in one basket with the 60 BRT.
If there are major problems (ala the Flx. 870's) they're going to be without buses and, this time, I don't think the likes of Washington's DC Transit will be there to help! (they're the ones that lent NYC 150 buses during their crisis).
Never very clever to put so much into something that really hasn't been proven!
And what makes matters worse is the fact that Nabi isn't exactly jumping to solve the problems!
We'll have to sit this one out and see what happens.
DE60LF
PostPosted: Thu Nov 22, 2007 11:01 am    Post subject: Reply with quote
This clearly shows that the New Flyer makes better articulated buses than NABI. However, New Flyer doesn't produce a CNG articulated bus, so NABI is basically LACMTA's only choice. Emissions laws in southern California don't allow TA's to purchase diesel-powered buses anymore, even if they are ULSD or diesel-electric hybrids. I even asked New Flyer why they don't make a C60LF, and they stated that the market for such model is too small, and that development is better spent on improving the DE60LF. However, if New Flyer made a GE60LF (gasoline-electric hybrid), I wonder if LACMTA would be interested.
inkybus
PostPosted: Thu Nov 22, 2007 2:22 pm    Post subject: Reply with quote
This question was asked in another thread, but would a gas- electric have the torque to move such a large bus? A diesel engine makes about twice the torque of an equivalent sized gasoline engine, so there should be some way to make up that, possibly in the gearing of the transmission.
View user's profile Send private message Visit poster's website Yahoo Messenger
DE60LF
PostPosted: Thu Nov 22, 2007 4:31 pm    Post subject: Reply with quote
I have heard that the GE40LF actually runs fairly well. In fact, I have heard that it accelerates faster than the DE40LF. The GE40LF uses a Ford Triton V10 engine. However, such technology is untested for a 60-foot articulated bus, and may not generate sufficient torque for a bus of its size.
Also, NABI is not the first manufacturer to offer an articulated bus in CNG. I believe that several European manufacturers have offered this technology for several years now. Neoplan USA has offered a CNG articulated bus for a very long time as well until their collapse.
inkybus
PostPosted: Thu Nov 22, 2007 8:55 pm    Post subject: Reply with quote
Now that you mention it, when I lived in San Bernardino I rode one of the three prototypes of the GE40LF and I do remember almost getting thrown out of my seat when leaving a bus stop. Thinking about it more, I think the torque is the result of the electric motor and not the gas engine, as motors have a high starting torque. It may be possible, if you use an electric motor with higher output, and possibly have the engine direct feed the batteries only instead of assisting the motor part of the time...
Sorry, I'm kind of rambling here... Embarassed
PostPosted: Sun Nov 25, 2007 12:51 am    Post subject: Reply with quote
I think that you might also want to consider the gearing of the rear end in any equation regarding torque regardless of the means by which power is transferred to it.
Gear ratios play an extremely important part not only in acceleration but in the handling of the weight that is exerted on the drive axle.
Using Cadillacs (of yore) as an illustration, when a trailer package option was selected the gear ratio was entirely different than what was offered in the standard rear end.
Of course, the transmissions and suspensions were also beefed up simultaneously.
There is really very little reason why alternate fuels will not work as well as gasoline or Diesel on artics if the drive train is engineered correctly.
inkybus
PostPosted: Mon Dec 03, 2007 11:20 pm    Post subject: Reply with quote
True, but you can only adjust the gearing low enough before you limit the top end. That may not be much of a problem in NYC, but here in SoCal where transit buses run 70+ mph there is a limit on how much you can adjust the gearing to compensate for the low torque of a gas engine.
Hmm, maybe this discussion should be moved here: http://hopetunnel.org/forum/viewtopic.php?t=656&highlight=
I guess it's up to the admin. Cool
PostPosted: Tue Dec 04, 2007 2:50 pm    Post subject: Reply with quote
inkybus,
Actually, this forum is O.K. because we are discussing Artics.
You make a good point with the extent to which ratios can be adjusted to accomodate both low and high speed operation.
Living here in L.A. myself, I notice that a great many transit routes do take to the freeways during some part of the runs and find it necessary to open it up so to speak just to keep up with traffic.
I think this is the main reason that GM years ago always suggested 4 and 5 speed manual transmissions on all OTR coaches which gave the driver far more control over the gear box and the transmission of power to the rear end.
Today, most OTR coaches come equipped with automatics but I don't think the concern is as much with get up and go as it is with top speed performance.
I guess you can't have both and get up and go is more important on transits.
Mr. Linsky - Green Bus Lines., Inc. Jamaicxa, NY
james123
PostPosted: Tue Jan 26, 2010 2:50 am    Post subject: Reply with quote
I get some good points through this forum.....thanks.@
PostPosted: Tue Jan 26, 2010 3:03 am    Post subject: Reply with quote
james123,
Glad we could be of assistance to you.
As an unofficial welcoming committee of one here at BusTalk, let me just do that and say that we very much look forward to your valued contributions.
Welcome aboard.
OCTA3053
PostPosted: Sat Jul 10, 2010 1:59 pm    Post subject: Reply with quote
after all the 45ft CompoBuses arrive, MTA isn't going back to NABI.
There's still quite a ways to go.
MTA are recieving the 2010 NABI 45C.05s. This involves bus # 8300-8359, which will go down to Division 18. With this being said and done, Division 15 in the valley are recieving some of the 6300s from Division 18. Not sure about D8.
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Sat Jul 10, 2010 3:28 pm    Post subject: Reply with quote
Interesting!
If LACMTA isn't going back to NABI, where are they heading?
Whatever they're doing or about to do is a wise choice only because I think they've already put too many eggs in one basket with NABI!
Not that I have anything against NABI - I think their 45 C's are great looking but I'm leery of the 60 BRT's that I see are already beginning to fall apart at the seams (and I mean the seems between the front and rear sections!).
We'll just have to wait and see what happens.
Post new topic   Reply to topic    BusTalk Forum Index -> Surface Transit - Western United States All times are GMT - 5 Hours
Goto page 1, 2  Next
Page 1 of 2
