Joined: 18 Dec 2007 Posts: 22777 Location: NEW JOISEY
Posted: Fri May 12, 2017 11:39 pm Post subject: |
NWP combine #356 was one of three still in regular service at the end of electric commuter service in 1941 (all were built by ST. LOUIS)
These combos were unique in that they were the only wooden NWP electrics to have enclosed ends................
http://www.newdavesrailpix.com/odds/ca/htm/nwp05.htm
(courtesy: newdavesrailpix) |
Posted: Sat May 13, 2017 1:59 pm Post subject: |
A bit more on NWP trivia:
"......the longest high voltage electric transmission line in the word carried hydroelectric power to the NWP's huge powerhouse at Alto........the alternating current signal and track circuit, essential to subway operations, was pioneered on the North Shore (NWP)........"
Posted: Sat May 13, 2017 7:10 pm Post subject: |
What does NWP stand for? Thanks. Joe |
Posted: Sat May 13, 2017 7:44 pm Post subject: |
N4 Jamaica wrote: | What does NWP stand for? Thanks. Joe |
Joe:
"NORTHWESTERN PACIFIC" <G>
Ferryboat/electric commuter train service (as noted here earlier) ended in 1941; mainline NWP passenger trains (with bus connections) lasted a while longer.
SP "branch line" tonnage, however, continued into more recent times, over trackage that had once carried the electric suburban trains....
Last edited by NEW YORK OMNIBUS 2629 on Tue Nov 14, 2023 12:19 am; edited 2 times in total |
Posted: Sat May 13, 2017 9:32 pm Post subject: |
Until 1939, the SP's "Red Electrics" and the Key System's MU's connected with commuter ferries at their respective pier terminals; in that same year, trains of both companies began operating via the Bay Bridge's lower level, to the new Transbay Terminal.
Until the NWP's total electric commuter service abandonment in 1941, double-ended passenger ferries* also operated out of Sausalito.
Like their New York Harbor counterparts, these huge vessels could load and unload passengers from both the upper and lower decks; however, unlike the New York ferries, the upper level loading aprons at terminals met the boat's upper decks from opposite sides (port and starboard) instead of the aprons lowering to the upper deck in the more traditional New York manner.
At the SP's OAKLAND MOLE terminal, as an example, the lower apron off the bow led main line passengers into the mainline portion in the terminal, whereas the upper (and lower) aprons on both sides led to the "Red Electric" commuter trains.
Sadly, no vestiges remain of these unique upper level gangways/loading aprons at the historic Ferry Building today, having vanished decades ago.............
Here are two interesting links, with much data and historic photos.......
http://www.cable-car-guy.com/ferry/html/yesterday.html
http://www.cable-car-guy.com/ferry/html/preserved.html
(courtesy: cable car guy.com)
*The "EUREKA" is the last surviving NWP boat, and is on exhibit today, and open to tourists. When the NWP abandoned electric commuter service in 1941, she went over to the SP, where she operated well into the 1950's.
She was also the last "walking beam" engine ferryboat to operate on the Bay.
Last edited by NEW YORK OMNIBUS 2629 on Sun May 14, 2017 9:05 am; edited 4 times in total |
Posted: Sat May 13, 2017 10:55 pm Post subject: |
Here is the "EUREKA", later in her illustrious career, when she was working on the SP crossing to Oakland Mole, where she connected to the mainline trains ("Red Electric" suburban service to Oakland Mole ended in 1939)
You can indeed see the similarities to the classic New York Harbor ferries that were then in operation......
http://www.cable-car-guy.com/ferry/images/eureka_john_schmale.jpg
(courtesy: cable car guy.com) |
Posted: Tue Nov 14, 2023 12:38 am Post subject: |
When it first opened in 1939, the Transbay Terminal was an electric railway "union station", serving the electric trains of three companies:
KEY SYSTEM
INTERURBAN ELECTRIC RAILWAY (ex-SP)
SACRAMENTO NORTHERN (SN)
The IER and SN trains only ran over the Bay Bridge trackage to the Transbay Terminal until 1941; during those few years, the SN had fewest trains out of the three companies.
Departures (especially during rush hours) were frequent on both the "KEY" and the IER.
Hat a new agency assumed operation of the Key's "Bridge Railway" in 1958, instead of converting rail operations to diesel buses, it would be interesting to see what new equipment might have eventually replace the old "Bridge Units", which dated back to the 1930's.
Perhaps stainless steel cars from BUDD?
Or, BOEING-style equipment, based on the then-new articulated light rail units?
I have long thought it ironic that the once-complex KEY system was thought old-fashioned and obsolete in 1958, and, barely a decade later, construction began on the BART network; suddenly, electric rail transit was, again, the "in" thing.
Interestingly, the KEY's rail services, now thought antiquated, ended in 1958, the very same year that SP ferry service across the Bay (the last ferry crossing in the Bay area) also came to a close (Oakland Pier-Ferry Building)............
["F-SAN FRANCISCO"] |
