Joined: 18 Dec 2007 Posts: 22712 Location: NEW JOISEY
Posted: Fri Apr 22, 2022 4:58 pm Post subject: |
From photos we've seen in the past, the oldest SURFACE and ex-FACCo buses indeed were the "Dangerfields" of that era ion their twilightyears....grimy, battered, weather-beaten....and, yet, somehow, STILL manage to run (at least, most of the time!)
["Ride The Surface Way'}
Posted: Fri Apr 22, 2022 5:05 pm Post subject: |
.......speaking of "weatherbeaten, battered, time-worn" old buses, here's an early 1960's "portrait" of a well-abused FACCo #1700, clearly a veteran bus that has seen little "respect" in recent years......
https://www.nycsubway.org/perl/show?156387
["Go The Motor Coach Way"]
Age: 57 Joined: 02 Oct 2014 Posts: 2427 Location: New York, New York, USA
Posted: Fri Apr 22, 2022 10:24 pm Post subject: |
NEW YORK OMNIBUS 2629 wrote: | .......speaking of "weatherbeaten, battered, time-worn" old buses, here's an early 1960's "portrait" of a well-abused FACCo #1700, clearly a veteran bus that has seen little "respect" in recent years......
["Go The Motor Coach Way"] |
It was indeed 1962, taken between 50th and 51st Streets actually and running on the #11 (which, prior to 1964, was based out of the 100th Street depot, now "Tuskegee Airmen"). But it - a postwar GM TD-4506 - actually started out on each side attributed to 'MADISON AVENUE COACH COMPANY, INC.' before being switched after November 1951 to 'NEW YORK CITY OMNIBUS CORPORATION'; 'FIFTH AVENUE COACH LINES INC.' was the third entity shown (but this was the fourth overall layout - FACL was initially stretched out all over directly above the passenger windows before being confined to that emergency exit as seen in that pic).
The maintenance practices of NYCO (which pre-1951 subsidiaries included Madison Avenue Coach and Eighth Avenue Coach Corporation) fell somewhere in-between the tip-top shape of FACCo buses (which "classic" Old Looks were in the 2200-2500 range) and the truly Dangerfield-ish Surface fleet (both GM and Mack). Not the best, but not hopelessly atrocious either. There are pics out there, mostly on WorthPoint, of #1700 when it first came into service under MACCO aegis. Certainly in better shape than by this point in time in that faded photo.
Below is how it looked restored more or less to what the colors should have been.
Description: |
#1700 on Route #11, taken on Ninth Avenue between 50th and 51st Street c.1962, restored (For educational purposes only.) |
Filesize: |
194.5 KB |
Viewed: |
7438 Time(s) |
Posted: Fri Apr 22, 2022 10:48 pm Post subject: |
Your's Truly started school in that same year (1962); I well recall NHBL's square-window Old Looks, soldiering on until about 1966.
From what I can recall, their buses were (at least at that time) pretty decently maintained.
Quick question on the earliest postwar FACCo Old Looks:
Were these GM buses all used to replace the open-top double-deckers, or were some also used to replace the old single-deck YELLOWS of the later 1930's?
Posted: Fri Apr 22, 2022 11:10 pm Post subject: |
This discussion has me know recalling the Ogden book on FACCo; the following just came to mind....not only were Fishbowls virtually ignored in this book, but, also glaringly absent were ANY photos of ex-FACCo buses running out their last years with the "Tee Yay".
If, ever, this book were to be reprinted, the following MUST be included:
1:
AT LEAST a few pages on the Fishbowls (or, better yet, several pages, including photos)
2:
Photos showing the last FACCO buses in service with the "Tee Yay"
3:
Photos/documents, etc. regarding the 1962 strike.....
Posted: Fri Apr 22, 2022 11:17 pm Post subject: |
Here's a nostalgic early 1960-s era of a "FIFTH AVENUE COACH LINES" Old Look (#2320)
Ahhh, remember when BUSES still looked like BUSES.......
https://www.pinterest.com/pin/531213718539065603/
{"Fifth Avenue Coach Lines"]
Posted: Fri Apr 22, 2022 11:22 pm Post subject: |
NEW YORK OMNIBUS 2629 wrote: | Quick question on the earliest postwar FACCo Old Looks:
Were these GM buses all used to replace the open-top double-deckers, or were some also used to replace the old single-deck YELLOWS of the later 1930's? |
During 1946 FACCo ordered Old Looks - TD-4506 and later TD/TDH-4507 - pretty much with replacement of the open-top double-deckers in mind. Am having trouble finding it now, but I have somewhere an image of a "Notice to Passengers" from late 1946 where it was mentioned that these new "Old Looks" were to be put on the #4 route to replace the open tops.
The later 1930's Yellows were still in service on crosstown routes in both Manhattan (6 72nd Street and 20 57th Street) and Queens (16 Elmhurst) well into the late 1950's. That is, if you're enquiring about the rebuilt 740's with the fronts rearranged to resemble their Old Look cousins. The earlier (1935) ones had to have been retired by the earlier '50's.
Posted: Fri Apr 22, 2022 11:30 pm Post subject: |
And here 'tis . . .
Description: |
'Important Notice' from FACCo, dated Dec. 19, 1946 (For educational purposes only.) |
Filesize: |
126.97 KB |
Viewed: |
7424 Time(s) |
Posted: Fri Apr 22, 2022 11:32 pm Post subject: |
Here's YELLOW #467, sporting the more modern Old Look front; had these buses had standee windows, the resemblence to Old Looks would have been even greater......
154383
["Yellow Coach 467"]
BTW:
THANK YOU for posting that rare piece of FACCo history!
Posted: Fri Apr 22, 2022 11:38 pm Post subject: |
NEW YORK OMNIBUS 2629 wrote: | Here's YELLOW #467, sporting the more modern Old Look front; had these buses had standee windows, the resemblence to Old Looks would have been even greater......
https://www.nycsubway.org/perl/show?154383
BTW:
THANK YOU for posting that rare piece of FACCo history! |
FACCo buses of that ilk would have been in the 1400's.
Posted: Fri Apr 22, 2022 11:40 pm Post subject: |
Here's a timeless, long-ago portrait of FACCo #2667 at South Ferry, one of the handsome and distinctive "buses with the sign that sticks out in front".
Sure wish we had some of these in my area of "Joisey".....
https://www.pinterest.com/pin/759841768352745452/
["6-Broadway"]
Last edited by NEW YORK OMNIBUS 2629 on Fri Apr 22, 2022 11:44 pm; edited 1 time in total |
Posted: Fri Apr 22, 2022 11:42 pm Post subject: |
NEW YORK OMNIBUS 2629 wrote: | Here's a timeless, long-ago portrait of FACCo #2627 at South Ferry, one of the handsome and distinctive "buses with the sign that sticks out in front".
https://www.pinterest.com/pin/759841768352745452/ |
#2667, actually, part of the set allotted to NYCO Division depots . . . 28 more buses built after this and the 'Old Look' era ended forever.
Posted: Fri Apr 22, 2022 11:47 pm Post subject: |
W.B. Fishbowl wrote: | NEW YORK OMNIBUS 2629 wrote: | Here's a timeless, long-ago portrait of FACCo #2627 at South Ferry, one of the handsome and distinctive "buses with the sign that sticks out in front".
#2667, actually, part of the set allotted to NYCO Division depots . . . 28 more buses built after this and the 'Old Look' era ended forever. |
And, of course, SURFACE also operated this type (#3020-#3059)
(too bad the "Tee-Yay" never ordered any of these)
Last edited by NEW YORK OMNIBUS 2629 on Fri Apr 22, 2022 11:55 pm; edited 1 time in total |
